I'm still cleaning up a slightly botched install. Today I decided to test the Roof ACs on my camper. What I understand is if I run a high load device like an AC unit. And I have shore power the Inverter should just pass power through to handle the load. I started my Honda 3000 generator got it warmed up. The batteries were at 95% and getting 1600 watts from PV. When the AC started the Cerbo GX showed it cut power from the generator for about 10 seconds then started to take power from it to supplement the demand. I can confirm it did use the inverter and batterys to start and run the AC because the generator idled down. I had battle Born assist me in the settings they had me turn on the UPS function. I don't know if this is why this happens? The AC was pulling about 1200 watts after it started I'm sure it was a lot more during the start. I don't have a soft start on the AC units yet, I'm adding them later in the spring. But need to get this system working right not to damage anything. The system is a Multi plus II 3000 12v , 2 Game Changer batteries 540AH total. 1800 watts PV, Lynx shunt and distributor, I don't think anything else matters with this issue? If you need more information please ask I'll add to it. I just don't want to burn up the Multi plus with it taking on the entire surge. My camper has a 50a connection. The generator was running thru a 50a to 30a adapter. Could that be the cause? Also the one AC is 15000 BTU the other is 13500 BTU. They are each on a separate leg as wired by the camper manufacturer. I only ran one at a time because I knew the generator can't handle both without a soft start. I want to have the ability to run Both in the summer when I'm connected to 50a Shore power.
