mccrane avatar image
mccrane asked
dbus Python driver fails when started as service
I have implemented a dbus Python service which works fine within the terminal but starting it as a service fails.
The service starts and is terminate within the same second;
"svstat /service/dbus-dummy" shows restarts every second with new PIDs:
root@raspberrypi2:~# svstat /service/dbus-dummy
/service/dbus-dummy: up (pid 24314) 0 seconds
/service/dbus-dummy: up (pid 24325) 0 seconds
The service works well when started in the terminal:
python /data/dbus-dummy/dbus-dummy.py
The dbus-spy shows a new service: com.victronenergy.dummyservice.ttyO1
Environment:
Venus/Raspberry v 2.89
I would be happy about any ideas or hints!
servicepython
pulquero avatar image
pulquero answered ·
What is the contents of your 'run' start script? if you are exec-ing your python, check you have the following as first line in your .py:
#!/usr/bin/env python
mccrane answered ·
The first python environment code line in the "official" example is "python 3"-please see the attachement.
I currently have no access to the system(out on holidays), I can post it next weekend.
An additional remark - there are no infos in the logs.
mccrane answered ·
Here the attachement with Python env statemen:
The /service/run bash script contains the right path and filename:
#!/bin/sh
mccrane answered ·
I was able to solve the issue...a trivial one - line feeds with CRLF in the run script!
I thought using "nano" to edit and renew all line feeds in the run script would prevent this.
But only:
> sed -i -e 's/\r$//' run
changes the CRLF to unix/bash style LF and the service starts imediately...
Thanks for your support!
pulquero answered ·
Ah that's annoying. Based on the other services, I personally use
#!/bin/sh
exec 2>&1
exec /data/BatteryProxy/battery_service.py
(which is what I assumed you were doing, hence my suggestion to check for a missing #!/usr/bin/env line)
