Tom Hart avatar image
Tom Hart asked
Multiplus II 24v stopped working after shore power disconnected
I have a Multiplus II 24v that has been working fine until I unplugged from a 50a shore power and now I cannot get it to turn back on. I am getting 26v at the terminal lugs. I also have tried turning everything off, waiting, then turn on, but still nothing
Multiplus-II
5 comments
Will it turn on if shore power reconnected?
Have you checked the turn on voltage in the Multiplus settings?
Tom Hart avatar image Tom Hart kevgermany ♦♦ commented ·
Works fine on shore, just shuts down when unplugged, where di I find turn on voltage
Alexandra avatar image Alexandra ♦ Tom Hart commented ·
@Tom Hart
If it works on shore power but no on inverting, then either
1. your batteries are dead/depleted or
2. the fuse/disconnect between the inverter has blown or tripped.
By 26v at the terminals are you measuring this with or without shore connected?
Tom Hart avatar image Tom Hart Alexandra ♦ commented ·
Batteries are fine, 26v is without shore also tests same at battery
You will beed to check your dc shutdown and restart values then under inverter
