sprinklerman1960 avatar image
sprinklerman1960 asked
Correct BMV wiring for multiple batteries/engines
bmv.pdfIs this schematic correct? Currently all the negative cables are attached to each other linking all four batteries and two engines together. I want to add the battery monitor to the house bank and I need to know if this is the right setup.
BMV Battery Monitor
bmv.pdf (20.5 KiB)
Paul B avatar image
Paul B answered ·
But if you are only wanting house loads then its basically correct.
the charging will only show whats going into the house bank
you show no fuses or isolation switch on any bank. plus no charging circuits ???
