jojogomez avatar image
jojogomez asked
CAN-BUS stops Communication
I Have an Polyontech Batterie connectet. All works fine, but after 6 hours I get the Alarm "low Batterie" What I see is, that the communication via CAN Bus stops. If I reboot the Victron all works fine again for the next Hours. A second problem is that after each Reboot I have the problem that the SMA Inverter connectet via TCP MOD Bus gets offline.
VE.Can
jetronic avatar image
jetronic answered ·
Hello, what does your system setup look like?
Are you using a Raspberry with CAN HAT or is it connected to a Cerbo?
jojogomez answered ·
Hello, I Use a Multiplus GX with direct Cable between Polyontech and Victron
