I have two Multiplus 3000/48 II (one GX & one non-GX) in single phase parallel, with Seplos Smart BMS communicating through CANBUS. Has been working fine for a month or two but for some reason when set on “inverter only” it can no longer cope with even small surges of energy usage. It triggers an “inverter overload alarm” about two seconds after switching on anything that uses a bit more electricity than normal (kettle or hair dryer or oven or microwave). It has worked with these items in inverter only mode before and I am trying to work out what I have done for it to stop working.
The physical setup hasn’t changed but I have been playing around in node red quite a bit.
I did have an ESS assistant installed (on both as per guidance) with identical setups when it worked fine. I have also tried without ESS and it still trips on a higher load.
Has anyone come across this before, thank you.
