mihair avatar image
mihair asked
MPPT Error #67 BMS conn lost and no output power after v1.40 firmware upgrade
Hi @mvader (Victron Energy Staff) @Guy Stewart (Victron Energy Staff)
After latest firmware upgrade i have lost my MPPT. Upgrade was successfully done via VRM
I did the following in order to make it work without success:
- CCGX rebooted
- system reseted
- BMS redetect battery
Please advise.
Thanks,
Mihai
MPPT Controllers
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ commented ·
Hi @MihaiR, thanks. We'll look into it remotely.
Hi @MihaiR, this turned out to be a mistake made in v1.40.
Thank you for helping fix this! v1.41 was released today.
I presume all is well again on your system?
mihair avatar image
mihair answered ·
Everything is back to normal, thank you so much!
MPPT version is C1.41. Is this different than 1.41?
Thanks,
Mihai
Hi, yes a letter before the version means that its a test version.
Best would be if you update your system to v1.41; the official one
mihair avatar image
mihair answered ·
I can not. Remote update via VRM seds is up to date
Ah yes. I understand now.
The trick in such case is to manually select a file, that you first download from victron professional.
