lennycb avatar image
lennycb asked
Undervoltage alarm - why?
Can someone explain to me why I keep getting an "undervoltage alarm"?
I had already turned the settings down.
DC input low-turn off: 40.8V
DC input restart: 41.8V
DC input low pre-alarm: 41.8V
In the ESS Assistant:
Sustain voltage: 45.0V
dynamic shutdown: all 4 values at 46V
I can not explain it.
alarm
@lenny.cb
Check your battery connections. They may be loose.
Alternative is the bms is somehow causing an issue there. Check cell balance.
