easysolar-ii gx shutdown after 2 hours on battery
Hi @james7111
Please ask your dealer to help you with the product, or hire an installer.
with the questions you ask and the information you give (nothing), no-one here can help you.
hi Daniel
i did have an installer do the setting and he has never had this problem before its a
is there away that you could login to check the settings for me
it would be greatly appreciated regards
james
what programming
I think @Alexandra means that the multiplus inside the Easysolar needs to be set up. First guess from me is the cut out battery voltage.
The manual covers the setup/programming
68 People are following this question.
