mimzy avatar image
mimzy asked
MPPT system stuck in float, not going to re-bulk.
All, I've noticed that my 4x 100/30 MPPTs are not going to back to bulk charge after the last firmware update. I did some searching and can't seem to find this issue.
I have 4x 100/30 MPPTs that are using a ve.network with a Bluetooth voltage and temp sender. I'm on a boat and the engines combined with solar will touch 14.4v when we are motoring and this will drive the MPPTs into absorption/float. After we turn off the engines, the boat quickly drops to 13.3v. My re-bulk is set to 0.01V with a float of 13.4. I have even ran a tea kettle to drop the voltage temporarily to 13.0v, but the MPPT still wouldn't re-enter bulk.
I have disconnected the ve.network and I can go into each MPPT independently to turn off charging, then on charging and getting them back to bulk.
Any thoughts or suggestions?
Thanks, Jason
smart solar charging behaviour
djsmiley avatar image djsmiley commented ·
Which batteries and what is the temperature? A lithium BMS with an active discharge off due to low-temp will cause identical issues.
mimzy avatar image mimzy djsmiley commented ·
800ah of Lithionics batteries. Batteries are sitting at 30C.
