phoenix avatar image
phoenix asked
Looking for a fuse part number/value on a Multiplus II 24/3000
I wasn't really sure where to post this. It seems better in questions than in modifications.
I have an MP II 24/3000 which had a small fire below it. The unit still works, but I need to replace a small number of components, mainly capacitors, on the main PCB that have suffered from heat damage.
There is one component, a fuse, that is still intact but the case has melted so I can't read the part number/value.
img-20221210-104003391-hdr.jpgThe fuse is situated to the left of the main heatsink and the right of the upright PCB. It's almost directly below the connector to the on/off/charger switch. There is only one fuse like that.
Would someone be kind enough to either read and post the part number, or post a photo. It's usually on the top. If the part number is not readily visible I'd strongly suggest to put the cover back!
Multiplus-II
