mr-no avatar image
mr-no asked
Multi RS Solar Setup Questions
I am planning to buy the Victron Mult RS Solar and have tried to get some information from the datasheet/manual/forum/DemoApp, but there are still some unanswered questions. I hope someone can help.
My planned setup:
- connecting the solar modules to the internal MPPT solar charger.
- connection of lead-AGM batteries
- connection of the public grid to the ACin connector
- only loads at output ACout1 (no connection to the public grid there)
The loads should be supplied by the inverter when the SOC of the battery is >70%. Below this value, the Mult RS Solar should switch the output to the utility grid (ACin) until the battery has again e.g. >80% SOC. Goal: The loads should be supplied primarily from PV and battery, but the battery should not be discharged below 70%, except there is no grid power. Also, I don't want any power feeding back to the public grid (from the ACin connection).
My questions:
1. is it possible to set up the Mult RS Solar to work as described?
2. can it be ensured that there is no grid feed-in over the ACin connector?
3. how fast is the internal transfer switch, if there is one (could not find a description in the manual and datasheet, but there are such symbols on the front of the unit). Is the switching synchronized with the mains frequency/phase? Is it the same transfer switch as described in the Multiplus II?
Thanx
setup
mr-no avatar image
mr-no answered ·
Nobody had an answer. So I will answer it by myself ;)
I bought a Multi RS Solar at my own risk and have tested and measured the behavior. I must say, the RS is a really good device and does fullfill all my requirements. I can only blame the lack of information in the manual or from other Victron information sources I checked - at least the information was not sufficient for my application.
Here some brief answers to my questions. Perhaps other can benefit from it.
1. yes, such a setup is possible (other than asked, I am controlling everything by the battery voltage and not by SOC, but that might also work - did not test it up to now)
2. I have not seen any grid feed in (continuously measured by a separate meter at ACin)
3. Now I know that it is not a real transfer switch. The Multi RS inverter output (ACout1) instead connects and disconnects to the power grid (ACin) depending on the operating condition. It is rather a hook up. This happens without any interruption (measured with an oscilloscope).
I am running on Firmware V1.11
gabius avatar image
gabius answered ·
The multi rs solar, can’t feed the grid yet, (sadly for me)
I use it with the same purpose as you, but with lifepo4 batteries, Pylontech, and now I added some diy battery Lifepo4, for a total of 25kwh.
The multi rs solar is really powerful and has a tons of options, I’m just waiting for the feed in greed option.
It’s sad not a lot of ppl talk about it, cause it’s so good in many cases.
