stigmata101 avatar image
stigmata101 asked
Load shedding and VE.Bus Error 24
Hey guys
I have a weird situation with a Multiplus 2 setup and cannot seem to find a fix.
There are 4 inverters installed forming a 3-phase system, with 2 on phase 1. When there is load shedding, I often get the error 24, though this does not happen every time.
I have checked the AC outputs and there is no difference between when the error occurs or does not occur. All readings seem almost identical, which I believe rules out the possibility of a high load causing the error.
With regards to the current sensor, there is no external sensor installed. Could this be a contributor? And if it could be, why does it not happen every time?
Appreciate any recommendations.
Multiplus-II
