Hi all,
I want to buy a 3000 multiplus ii 48v that:
1. Will be connected to the grid in AC in through a simple cable plugged to a schuko plug.
2. Will be connected to a set of batteries
3. The batteries can be charged either through a smart solar charger and PV
4. Or through the ac in of the inverter.
I've read that the inverter can send excess power to the grid which in this case I don't want to do.
So what I want to do is the multiplus to operate as a simple UPS in the sense that it will not send power back to the grid and only consume power first from the batteries and when they reach 20% switch to the grid.
Will that be possible ?
And if yes could you suggest what to read to achieve it?
