Herve RV Nizard avatar image
Herve RV Nizard asked
Grid assist settings
Good day. New to victron. Familiar with outback.
Asking for advice on a multiplus.
User of grid assist system to get AC In from the grid if batteries get low. But I DO NOT want the grid to recharge my batteries; simply to supply the loads if batteries get below 12 v.
Can i set this for a multiplus ? Via which device or software .
Where do i find instructions ?
Thanks
Paul B avatar image
Paul B answered ·
have alook through the ESS setup https://www.victronenergy.com/live/ess:start
or you could maybe write a assistant if you are good at programming
Thye ess gets close if you limit the grid setpoint and the min SOC settings
Boekel is also very good and knowlagble in this area and may have some extra advise
