mufassa avatar image
mufassa asked
Virtual Switch override ignore AC
Using the virtual switch, setup Quattros to ignore AC1 until batteries at 5%. Works nicely. However I want to force charge based on half-hourly slots when I require - is there a way to force charging when AC1 is ignored or to temporarily disable Ignore AC1 setting? (Ideally I'll do it with modbus - but understanding manually would be a good start).
Not using ESS, as using VS.
