mufassa avatar image
mufassa asked
Assistant to change invertor state
Is one of the assistants able to change the inverter state (3-phase Quattros) from 'On' to 'Inverter Only' and back again based on charge level?
Looking at trying to create a safety mechanism based on some scripts I have created to charge based on Octopus Agile spot prices, but a safety mechanism to say re-connect grid if battery SOC reaches >10% would be reassuring...
Alexandra avatar image
Alexandra answered ·
mufassa avatar image mufassa commented ·
Thanks! I think I am coming to the realisation I need to be using VS not ESS for this system given the inverter metering bug which seems to exist, which will solve my issue and just live with an inverter priority setup
Alexandra avatar image Alexandra ♦ mufassa commented ·
The other way, if you want the ability to override the programmed connection is this way.
