Hallo
yesterday I found this : https://github.com/victronenergy/dbus-shelly
a driver for shelly devices from Victron
I did some tests , but I can't install, the makefile is the problem for me
have you a howto or some links for me
Thanks
Hallo
Thanks
Okay
Sorry, for me this is not the same
this :
is from victronenergy
I think this is "native"
Okay
I got it
installed this https://github.com/victronenergy/dbus-shelly/archive/eccbe89f1e447e977cf3db597469ff219d259804.zip
this is a driver for Shelly 3EM from Victron, v0.2
the last version v0.4 is only for shelly gen 2 devices
and then you get this :
it is detected via mdns, the only thing to do is set the role :
Thanks to Victron
great Work
Hallo
unzip all to /data/dbus-shelly
and to /data/dbus-shelly/ext unzip this : https://github.com/victronenergy/velib_python/archive/refs/heads/master.zip
and then run :
python dbus_shelly.py
does anyone else have the problem with firmware 2.92 and the advice above to get this not to work?
Everytime i tried tp python dbus_shelly.py i get the the error module websockets:
File "dbus_shelly.py", line 8, in <module>
import websockets
ModuleNotFoundError: No module named 'websockets'
Thx in advance and br
I think you have to install websockets
python -m pip install websockets
hallo fmac,
thanks for yourt reply. I tried and got this error:
Traceback (most recent call last):
File "/usr/lib/python3.8/runpy.py", line 185, in _run_module_as_main
mod_name, mod_spec, code = _get_module_details(mod_name, _Error)
File "/usr/lib/python3.8/runpy.py", line 144, in _get_module_details
return _get_module_details(pkg_main_name, error)
File "/usr/lib/python3.8/runpy.py", line 111, in _get_module_details
__import__(pkg_name)
File "/usr/lib/python3.8/site-packages/pip-6.0.7-py3.8.egg/pip/__init__.py", line 13, in <module>
from pip.utils import get_installed_distributions, get_prog
File "/usr/lib/python3.8/site-packages/pip-6.0.7-py3.8.egg/pip/utils/__init__.py", line 22, in <module>
from pip._vendor import pkg_resources, six
File "/usr/lib/python3.8/site-packages/pip-6.0.7-py3.8.egg/pip/_vendor/pkg_resources/__init__.py", line 1649, in <module>
register_loader_type(importlib_bootstrap.SourceFileLoader, DefaultProvider)
AttributeError: module 'importlib._bootstrap' has no attribute 'SourceFileLoader'
i am nearly done all i could do, but i don't get it to work :(
Maybe you have another idea...
Thanks in adv and br
I unzipped the 0.4 for the ShellyPro4PM ....when I run the dbus_shelly.py, the Shelly is registered but I did not get any energy data. The updated aiovelib is installed as well. Any advice?
Sorry no good news
I got a Shelly Plus 1PM
but the same for me
its connected, but no data for V, A or anything
I don't seem to be able to get this to run either.
Download from githib to /data
unzip to dbus-shelly/
root@nanopi:/data/dbus-shelly# python dbus_shelly.py Traceback (most recent call last): File "dbus_shelly.py", line 22, in <module> from aiovelib.service import Service ModuleNotFoundError: No module named 'aiovelib'
Is there any updates or official documentation here from Victron?
You would need to add the aiovelib files in the ext directory - they are not included in the dbus-shelly zip. But don't bother, this driver, for gen2 devices, is already included in the latest Venus releases.
Experiments, Modifications and Adaptions. Mods (Modifications) can be made to Victron Software by the Community. Please use the modifications space for enthusiasts who want to push what is possible, without official Victron Support.
42 People are following this question.
