rankbajin avatar image
rankbajin asked
Multiplus 12 1200 50 - not working on initial set-up
I have a brand new Multiplus which I have just installed. It's not connected to AC yet but there's no power when connected to DC. The ambient temperature is around freezing but I thought the LED's would at least work to show it's on.
Multiplus-II
cardy01 avatar image
cardy01 answered ·
Maybe a dumb question but have you switched it on?
nickdb avatar image
nickdb answered ·
You haven’t mentioned what batteries these are. Not impossible, if they are Lithium, that they have disabled discharge.
cardy01 answered ·
I assume it wasn't a dumb question?
Might just be that @Rankbajin hasn't seen the answers.
rankbajin answered ·
I’ve just picked this up so apologies for the delay.
It’s connected to a 160ah lithium Victron battery. There is 13.4v getting to the Multiplus. When switched on in either inverter or charger mode there is a very very brief green light in charger mode before it goes to a solid red light in Alarm mode.
After my initial post I connected the VE Bus BMS cable to the battery which I had omitted to do.
TIA
cardy01 answered ·
I'd say that's normal behaviour .... the AC in and AC out have relays to provide functionality
In charger mode the AC in is not seeing a voltage so generates an error because it can't charge
In inverter mode the relay provides a neutral earth bond
I think you need at least AC on AC in to test the "box"
Thanks for your reply. I connected the AC and saw that I had 240v going into the inverter but still the same result as before.
It's been suggested that I change the DIP switch settings but I assumed it would be good to go out the box.
I changed the DIP switch settings and the Multiplus works on inverter mode only when the RJ45 connecter is disconnected from the Multiplus.
