checkthisout avatar image
checkthisout asked
Multiplus 24/3000/70 charger only mode question.
Hello. When in charger only mode, will the multiplus still monitor battery voltage and activate its programmable relays (such as one programmed for gen start when battery is low)?
What is it's wattage consumption when in charger only mode? (No a/c power applied, just sitting there with the switch in charger only position)?
offroadflow avatar image offroadflow commented ·
No consumption when in "charger only" mode. At least negligible...
About the relais I'm not sure but you can access the inverter through VE config so I reckon it's all active and in "waiting" but please wait for more answers on this...
