i am going fully offgrid,, using smartsolar for dc coupling, and also would like a mutliplus 2 5kw to grid refererence a pv inverter, the pv inverter i have is a aurora power one uno, would that be ok to run with the multiplus 2 please
I use the aurora power One 3kW without an issue coupled with a 5kVA Phoenix (Off-grid).
There are no comms, but frequency-shifting works with the PV assistant.
32 People are following this question.
DC Power + AC Load not equaling Battery Discharge rate
Using Smart Shunt as DC Load meter - VRM is not mapping correctly
When BMS Switch DC off and grid is available, why Multiplus Switch off the Full House (AC)?
Looking for engineering support
Has DC System - Incorrect Consumption in VRM when Phoenix Inverter is run on DC
