what will happen to the Mulitplus or the SmartSolar Charger, it a smart BMS of a 12V LiFePO4 Batterie ( in my case from Renogy) will enter the protection mode and open its relais? With an other Inverter and solarcharger i got a damaged inverter finally......
How is the SmartSolar Charger and the Multiplus protected against such Loaddumps ?
