When I use an ordinary LAN cable to connect VE-Bus from the MPII Inverter to Cerbo-GX my system shows an error on the MPII-3000-35-48 and stops charging from MPPT250-70.
So what is the pinout of the VE-Bus cables please?
It's just a standard straight-through LAN patch cable (NOT a crossover cable.) So long as the colours are same at each end it should work; these are normally wired as per T568B though.
Problem is probably low quality cables, or lower speed lan cables which do not have all pins wired.
34 People are following this question.
