torgnysaker avatar image
torgnysaker asked
Error #15 - VE.bus combination error
I have a system containing
1: Quattro 48/10000/140-2x100
2: Lynx Distribution system(DC in, Shunt, BMS, Distributor)
3: SmartSolar MPPT VE.Can 250/100 rev2
4: Color Control GX
5: Battery bank 400 Ah Smart Lithium batteries
When i start the system with the Quattro Charge i get
Error #15 - VE.bus error
The inverters Bulk+ Iverting flicker Absobtion steady, after a while Quattro is off and it all start again.
If i put the quattro to on Low battery is lit (measured battery voltage > 54V) and after that the same as when quattro in charge only occur.
All FW are the latest versions
Can anyone help me?
quattro 10kva
mito avatar image mito commented ·
Ooopps !!!. I got today exactly same results in from the grass installation, both the VE-Bus error #15 and Low Battery Voltage error (Voltage is 50,5 Volts, so OK not low) . Quattro 48/10K and Pylontech batteries. Any clue?
Hi, could it be that your Multi is configured for having a VE.Bus BMS (which is a very specific type of BMS; which you don’t have in your system) ?
Thats one of the reasons for the error 15:
Multi configured for having a VE.Bus BMS installed, but receiving commands from a BMS elsewhere, connected to the GX Device, ie via DVCC.
