will11456 avatar image
will11456 asked
VE Direct Logic level
Hi im looking for some help with VE Direct.
I want to connect to a Pi UART which should support it natively due to it being TTL albeit at a 3.3/5V logic level.
However im aware some devices on VE Direct are 3.3 Logic (BMV700) and ive seen the Victron say their VE Direct adapters 'Adapt' to either 5 or 3V respectively. Is there any info on what IC is handling this? Or is simply using 3V logic sufficient as it will work with 5V TTL on victron devices?
Has anyone got any Venus or Cerbo gx they could tell me whats chips are around the VE.direct connectors for me?
Cheers.
VE.Direct
