Dear all,
Just to be sure that if I use the BMV-702 to monitor just one battery instead of multiples it will work properly?
Thanks!
Dear all,
Thanks!
Yes no problem.
You can either leave the 2nd input unused, or buy the temperature sensor accessory and monitor the battery temperature.
If you also have a SmartSolar Victron MPPT, consider the BMV-712 as you can Bluetooth link it to the MPPT to improve the charge voltages.
how would you conect the bmv 712 to the charge controller using bluetootg
With a VE.Smart network. It is explained here:
https://www.victronenergy.com/live/victronconnect:ve-smart-networking
8 People are following this question.
