This seems to be a new problem. I attempted performing a manual equalize. This is of course after being in Float mode and having finished a full bulk/absorb charge. Equalize only uses the absorb voltage. it completely ignores my equalize voltage setting. It also seems to be allowing WAY too much current through. I have my equalize current set at 7%, should be 5.32 amps but it seems to be giving the charge all the amps available, just before the sun is down it's cranking 52 amps in... so is the manual equalize function completely broken at this point? Sure seems to be
