pedaaa avatar image
pedaaa asked
is there any experiance using 48V diesel or gasoline generators/chargers for ESS ?
i am using 3x Multiplus II 5000 for my ESS.
And i think about adding a fossil fuel based generator as a backup-system.
As my multis have no 2nd AC-input, and i don´t want to change to quattros, i think about installing a 48V DC-Generator, that only charges my batteries.
This should be a simple integration, isn´t it?
This could be configured by "has DC-load", and it should show as negative DC-load in VRM, correct?
I found that there are already a limited number of such 48V DC generators/chargers available on the market, see e.g:
https://koenner-soehnen.com/generator-ks-48v-dc
or some cheap chinese untis, which seem to be somehow common for Telecom applications:
https://www.alibaba.com/product-detail/5KW-Diesel-DC-Generator-Telecom-generator_1600136327490.html?spm=a2700.galleryofferlist.normal_offer.d_title.31f712adBKAlMr
So my question is:
Has anybody any experiance with this approach?
Are there any 48V DC generators that have been tested or can be recommended for this approach?
thanks to everybody!
ESSGenerator
cargol66 avatar image
cargol66 answered ·
You mean 3 Mplus II because you're working with tri-phases system ?
If not, i've seen many diagram with Multiplus II and power gen as backup.
may be this will help you:
https://www.victronenergy.com/upload/documents/Energy_Storage_System/ESS_design_and_installation_manual-en.pdf
Regards.
Bruno.
Phil Gavin avatar image
Phil Gavin answered ·
