nir-fsight avatar image
nir-fsight asked
MQTT Disconnection
I have connection to the victronenergy MQTT server (mqtt.victronenergy.com) using MQTT.fx client. this allows me to subscribe to topics but i get no notifications.
Once i go to the victron VRM portal, and click on "remote console" I suddenly get all the information from the topic. after a while, I need to do it again to get the data stream.
What is the issue? how can we resolve it?
thanks
Nir
MQTT
mrtn avatar image mrtn commented ·
Im trying to access mqtt.victronenergy.com with MQTT.fx
I have a problem of not being able to connect. MQTT is enabled in the Venus. I suspect the problem might be with the SSL setup of my connection that I added in MQTT.fx. I have double checked my credentials (email and PW for Could you please share what you have done to get MQTT.fx to connect?
ERROR --- BrokerConnectService : Unable to connect to server
Thanks
nigelfxs avatar image
nigelfxs answered ·
See https://github.com/victronenergy/dbus-mqtt#keep-alive for a description on how to do this.
damonz avatar image
damonz answered ·
It could also happen if you have set the client ID the same as your VRM Portal ID. Just use the generate ID button in mqtt.fx to generate a random client ID.
Regards,
Damon
