Howard avatar image
Howard asked
Quattro 10kva, AC1 Mains AC2 Genset : AC1 & AC2 control ?
System setup. AC1 essential loads, AC2 non essential loads
Grid failure, power via battery through inverter to AC1 loads only
Generator start. power on AC1 loads only.
We wish to have power on AC2 Loads as well. Is this possible?
quattro 10kva
shaneyake avatar image
shaneyake answered ·
Yes, you can use the Assistants to program how AC2 works in VE.Config.
Programmable relay Assistant is the one you want.
Jason - UK avatar image Jason - UK commented ·
@shaneyake Every day is a school day. I didn't know you can keep AC out 2 live in the event of a failure of supply on AC in1. Thank you, I'll give that a go on my set up.
Howard avatar image
Howard answered ·
Repost with a little more detail.
Quattro 10kva, AC1 in Mains, AC2 in Genset : AC1 out & AC2 out control ?
Quattro 10kva, AC1in is grid Mains AC2 in is a Genset : AC1 out & AC2 out control ?
System setup. AC1 out is for essential loads, AC2 out is for non essential loads.
When in grid failure, power via battery through inverter to AC1 out loads only
When forced generator start via Cerbo. power on AC1 out only.
We wish to have power on form generator AC2 input to AC1 out as well as AC2 out. ???
Is this possible?
Please assist
shaneyake avatar image shaneyake commented ·
Yes, it is possible.
You need to use the VE.Config software to program the Relay Assistant to control AC2 output how you would like.
