myvicrocks avatar image
myvicrocks asked
MQTT - Setup but not publishing
Hi there,
I have followed: MQTT local & via MQTT broker - Victron Community (victronenergy.com)
I setup the MQTT service both SSL and Plain text in my Cerbo. I use MQTT Explorer to view the MQTT broker. I can see : N/c0619ab1asd32/system/0 but the only sub topic is serial. There isnt any other topics like in the link above (Battery, AC etc etc).
I am wondering what I missed so it publishes the rest of the info?
MQTT
taylortops avatar image taylortops commented ·
If you're using Javascript, I can help you with some code. There are lot of Python and command line examples in this forum. If you're doing it in C, I can recommend a good psychologist.
But, on first glance:
  • Read keep alive as per Thomas' suggestion, once every 55 seconds . For your case, that would be: "R/c0619ab1asd32/keepalive ", nothing in the body.
Thomas avatar image
Thomas answered ·
you have to send a message to the mqtt-broker on a regular base.
https://community.victronenergy.com/questions/153464/mqtt-cerbo-gx-sendet-nur-die-seriennummer.html
For test you can send it from the mqtt-explorer. It will stop sending data about one minute later.
I am using a linux-pc to collect the data from the mqtt-broker and the regular message is sent via a cronjob every minute.
Best regards
Thomas
