With the ability to change the low voltage settings in the inverter, is it possible to run say a Phoenix 48V 1200 on 24v? If so would it just be at a lower output due to input current limitations?
A 48V Phoenix will not run at 24V. In the datasheet you can see an input voltage range.
31 People are following this question.
