abuonocore avatar image
abuonocore asked
ARGOFET alternator cable fusing
Should I FUSE the cable connection between the alternator B+ output and the Argofet Input ? On which side (close to alternator or close to argofet ?)
THe alternator has a rated output of 55A (Hitachi LR 155-20 for Yanmar) and the cable is 35mmq, than can carry all of the current. I don't believe there can be a fire risk on the cable, if there is a short on either side of the cable. May be the alternator can burn if it sees a short at the output, but I cant fuse less than 55A, and If I use a larger fuse I don't think there is much more short circuit current enough to blow a say 70A slow fuse.
ANy recommendation ?
Thanks
ALberto
fusesalternatorArgo FET Diode
Product page Argofet Battery Isolators
Product page Argodiode Battery Isolators
Product page Diode Battery Combiners
Fuses & fuse holders Product Page.
