Mike Baehre avatar image
Mike Baehre asked
Power draw during float
Shouldn’t the MPPT be able to see a load (for example 6A refrigerator) and adjust the amps going to the battery during Float?
I routinely see my system in float (13.3V, 2A) on a nice sunny day when our boat fridge comes on (6A) and the battery monitor shows about -4A. Shouldn’t the MPPT be able to see this load and adjust the Amps it is putting out?
Configuration on my boat:
All components Bluetooth enabled and communicating with each other when I check their settings.
310W panel going to 100/30 Smartsolar MPPT
2 x 140W panels going 100/30 Smartsolar MPPT
BMV-712 monitor
Smart battery sense
12v boat system
500AHr house bank (4 x 125 AHr Lifeline AGMs)
MPPT Controllers
klim8skeptic avatar image
klim8skeptic answered ·
13.2v is to low to set the mppt float voltage.
@Mike Baehre
MPPTs use battery voltage to decide when to switch out of float. Apart from your low float setting, your large house bank won't show a significant voltage drop under this low load. They will continue to charge from the float current.
If you wish, the voltage drop required can be adjusted, default is 0.4V, reducing this will restart the charge cycle once the voltage drop is reached. Making this setting too sensitive will reduce battery life, so don't overdo it.
