Fuso avatar image
Fuso asked
battery charger settings for an EasySolar 24/3000/70 when changing to a LifePo4 battery
I have just replaced an AGM battery with LifePo4 & Daly BMS. I have changed the MPPT settings ok but haven't been able to find information on how to change the battery charger settings. Can these be done with dip switches or is connection via the VRM port required ?
charger
klim8skeptic avatar image
klim8skeptic answered ·
It would be best to look at the VictronConnect - VE.Bus Configuration guide.
kevgermany avatar image
kevgermany answered ·
Dip switch settings are in the manual for the multiplus inside your easysolar.
Compare the battery maker's recommendations to the options you have. You should be able to get there.
But ideally follow @klim8skeptic route.
Chargers.
