Victron's information about Pylontech batteries with Multiplus inverter/chargers does not include the Multiplus-II, which I presumed meant that it was not yet officially "approved". Could anyone confirm the actual status?
You can safely assume it applies to the Multiplus II as it is approved for the Multiplus range of devices. Forward compatibility should typically not be a problem. I have a BlueNova connected to my Multiplus II which is the same scenario and it is fully supported. Just stick to the provided setup documentation and you will be fine.
8 People are following this question.
