Basically is GUI mods OK to use on a primary system?
Does it compromise the stability of the Venus OS?
Cheers....
Cheers....
I would have no reservations adding GuiMods to a mission critical system.
As with any mission critical system, disable automatic updates (including Venus OS) and plan your updates and do them manually. Also if possible, run a test system and do updates on it before the mission critical system.
30 People are following this question.
