ahaz-alex avatar image
ahaz-alex asked
Multi RS Solar 48/6000 Error 27
Hey,
I've just received my new Multi RS Solar 48/6000.
Connected only to a 48v / 300ah lead acid battery system, it shows error 27.
I can reach it via Bluetooth, but the inverter part won't start. Also when I connect PV, it doesn't show the voltages.
Any ideas besides returning the unit?
Kind regards
Alex
MPPT Controllers
ahaz-alex avatar image ahaz-alex commented ·
Yes, tried that multiple times, as well with different sources (batteries, PV, public grid at AC In, and all combinations).
Always with 10 minutes break. Didn't help :-(
Matthias Lange - DE avatar image Matthias Lange - DE ♦ ahaz-alex commented ·
Ok, in that case I guess you have to take it back to your seller to get a replacement.
Alexandra avatar image
Alexandra answered ·
@Ahaz_Alex
Reset the settings. Update the firmware.
Remove everything from the system. Wait 10 minutes. Make sure all is discharged internally.
Connect the battery using a precharge resistor or circuit.
Then try again with setting up the paramters, connect ac wiring, solar etc.
@Alexandra Thanks for this genius idea. Shame on me for not trying that before.
Disconnected everything, waited half an hour, used a 50v 10a laboratory psu with a 1A inrush limit. Connected, booting, error 27....
Damn, nice try, so thank you.
Current is at 30mA after the inrush moment. Seems legit for me.
Alexandra avatar image Alexandra ♦ ahaz-alex commented ·
@Ahaz_Alex
Sucks that it didnt work though...
You have definitely made a good go at it though.
