dliska avatar image
dliska asked
Flow restriction to/from distribution network with Victron Multiplus system
I would like to ask you for advice on setting up the Victron system with 2 Multiplus 48/5000 converters.
We have been operating a Victron hybrid system with 2 controllers 250/100 and 2 Multiplus 48/5000 converters for a year.
The problem is that when there is an input power supply from two phases of the distribution network on 2 pcs of 48/5000 converters, even with sufficient power from the panels, there are considerable flows from/to the distribution network
As an example, I can give e.g. the output from the panels is 5kW and the consumption is only 500W, the system still inexplicably "sucks" itself from the distribution network
How to achieve that the system behaves in the given conditions as an island and the flows from/to the distribution network
 are close to zero.
multiplus ve.bus
