marommel avatar image
marommel asked
node red: change value of active SOC
Hi, ist there any node or other solution to change the "active SOC" using node Red?
edit for clarification: I mean the value of the active SOC that is set by the BatteryLive function
Thanks, Markus
SOCNode-RED
nickdb avatar image
nickdb answered ·
Not via node red.
marommel answered ·
would the exec node be worth trying it? I just somewhere read there are permission "problems"
I succeeded changing that value by using the shell. Would just be one line of code to execute:
dbus -y com.victronenergy.settings /Settings/CGwacs/BatteryLife/SocLimit SetValue 25
marommel answered ·
Today I could try the exec node. It's working. With this flow, you can change active and min SOC by slider.
flows1.zip (1.9 KiB)
hominidae avatar image
hominidae answered ·
...you can simply set these values via mqtt as well.
