pgrayatmac avatar image
pgrayatmac asked
Connect BMV-712 from shunt to display using VE Direct cable
Hi I'm trying to update an Airstream Basecamp with the BMV-712. The existing system has a victron display connected via ve.direct cable from the non-Bluetooth SmartSolar 150/35 MPPT. The BMV-712 display has a ve.direct plug, but the shunt only has an rj12. I don't want to have to rewire the system to use the same space as the existing display. Can I just splice the end of the ve.direct cable to a rj12 plug or does it use more than 4 pins? Is there an adaptor? Should I just give up and return the BMV-712 and go with a smartshunt and a dead display?
wiring
kevgermany avatar image
kevgermany answered ·
The ve.direct connection from the 712 must go to a GX device. You don't say which screen you have, but if it's the Colour Control GX, there are VE.Direct sockets on the back. Don't splice cables, the system isn't designed for it.
The bmv 712 has clever bits in the display, wont work without it.
