I'm just setting up a 14kWh AC coupled battery system using the above inverter (48v / 5000w version). I have tried to find the answer to getting scheduled charging working, all I have found is the need to install ESS Assistant and then it's claimed that the schedule charging appears.
Nothing has appeared on mine either in software or on the inverter display.
Please can some one point me in the direction of getting this sorted before I embark on getting communication running between MP II and Seplos BMS.
Many thanks in anticipation - J
