victronboat avatar image
victronboat asked
Bmv712 logging spikes
Hi everyone,
The victron VRM could be set to log each minute.
If I have a system that draws 300mA and from time to time I get theese spikes at 20Amp for 10 secounds. Will the spikes be logged in VRM? I guess not, beacuse the chance of logging when the spike is happening is not that high so It is most likely to log when the current is 300mA. I understand that the spikes will be calculated in the energy consumption calculation, but the spikes will not be measured? Can someone confirm or not confirm my thinking?
Thank you
BMV Battery Monitor
Alexandra avatar image
Alexandra answered ·
@victronboat
Confirmed 60second logging misses the 59seconds where stuff could happen.
Trends in victron connect works better for the spikes. But can also miss them.
victronboat avatar image victronboat commented ·
Thank you very much!
