Today there was power interruption from the grid at 11:10 and then at 12:10 there was sun behind the cloud and after that my 3 phase system multi in phase 3 started acting very weird.
I have grid paralel system, so Out1 and Out2 is not used in Multiplus II.
In this image you can see that P3 did not resumed charging the battery but other phases did (load and PV generation did not change after 12:10)
I suspect that something broke inside, in this video you can see how Phase 3 is exporting in full power and then importing in full power.
https://www.youtube.com/shorts/qywkfpWE2Fw
So right now I had to turn multis off because of that Phase 3 problem.
Tested that if I set them to charger only I can charge the battery also with that Phase 3 multi, but when I set them to Inverter only then they are doing nothing (I suspect that they can only invert only to OUT-puts).
