antiguasky avatar image
antiguasky asked
Orion TR 48/12 -30 Amperage Exposure on input side
Is there a maximum amperage that the converter can be exposed to on the input side? My 48V side can create amperage as high as 120A and I want to be sure that the converter won’t see that as an issue and just draw what it needs from the available power.
Orion DC-DC Converters not smart
JohnC avatar image
JohnC answered ·
That'll be fine. The unit will only draw what it needs, like a max of ~7A @ 48V. Good practice might see you fuse both the +ve input/output wires, just for protection of the wires.
A short circuited load I'm not going to test mine for. :) Fusing should defend against that anyway.
