hansgeorgk avatar image
hansgeorgk asked
MPPT 250/70 in Easysolar 2 GX 24/3000 stops charging below at approx 25.5V
bildschirmfoto-2022-10-29-um-174304.pngHi,
the MPPT 250/70 in my Easysolar 2 GX 24/3000 stops charging at approx 25.5V. See screenshots. Batteries (LifePo4, 280AH) are at approx 20% :-(
I started using the LifPO preset
Batteries did not charge and using AC input MPPT went into ERR#38.
I found one article describing a workaround using AGM settings and adjust voltages
bildschirmfoto-2022-10-29-um-173927.pngI can now load the Batteries using AC input and I am not getting Err#38 any more.
Still issue with PV charging is not solved ...
any ideas what is going on?
MPPT Controllers
