westen avatar image
westen asked
Globballink 520 relay, but how?
Have a question about the relay function of the Globallink 520. I have basic knowledge on electronics. I know for instance the positive side of a battery is the side with the "knobby" thing on it's end. My question is: since the Globallink relay cannot be fed more than 3V (otherwise it explodes) am I right to assume I should get a (another) relay that has 3V on the one side, so it will trigger it's relayswitch so that I can switch on a bigger load? Or, if I am mistaken, how do I switch a substantial (10A, 12V) load with the relay onboard the Globallink 520? Please take me through this step by step and bear in mind my complete and utter ignorance on the matter.
globallink
Øystein Hennø avatar image
Øystein Hennø answered ·
I think you have wrong information:
It's able to switch maximum 60Vdc / 3A
I am running/controlling 12Vdc units on it without any issues.
If you need to control a 10A source, simply let this relay control another relay able of handling your 12V/10A load.
westen avatar image
westen answered ·
Thanks Henno, for your helpful anwser.
