Can I use different models of Multiplus II (e.g. 2000va and 3000va) to create a split phase output between the two? Or do they have to be the same model?
63 People are following this question.
Multiplus ii 5000 not inverting 4000w
Search Mode for four Multiplus II in parallel + split phase (2+2 configuration)
>10kVA and dedicated production meter
firmware compatibility three phase system MultiGrid-II and MultiPlus-II
Split-phase boat power system with MultiPlus-II 2x120 and Autotransformer
