victronthumbsup avatar image
victronthumbsup asked
MPPT150|35 Overvoltage without solar panels conncted
Hello Victron community,
I have a problem with one of my MPPT150|35A. Eventough I disconnect the solar panels I still get an overvoltage error #33 (Error code: #33 - Input voltage too high).
My setup consists of a pylontech battery and five MPPT150|35A controlled and monitored by a Cerbo GX. Every MPPT150|35A is connected to 6 solar panels. Three in a row and two in parallel. The open circuit voltage of a single solar panel 41.14 V so 124.2 V is the max string voltage.
All MPPT150|35A work like a charm expect one MPPT. This MPPT drops the error #33 overvoltage. The max voltage in the history of the MPPT is 130V.
First thought was, that this solar panels have the longest distance to the MPPT with approx 30m and the inductivity might be a problem.. I tested other panels with shorter cables and got the same error. Today I disconnected the solar panels completely and still have the same problem.
What are your ideas?
Thank you very much!
MPPT Controllersovervoltage
Alexandra avatar image
Alexandra answered ·
@VictronThumbsUp
Did you uodate the firmware?
What programming have you done? Did the mppt detect the correct system voltage?
Was there an arc when you connected them?
victronthumbsup answered ·
@Alexandra
Hi Alexandra,
the firmware version is the same as an all other MPPTs. It is the newest. The configuration is also the same. I get no sparks as I use switches.
@VictronThumbsUp
Will have to send it back to seller or delawrshio for an RMA.
Is it reading the battery voltage correctly?
victronthumbsup avatar image victronthumbsup Alexandra ♦ commented ·
Yes, the voltage reading is very close to the values of the other MPPTs. I will have to sent it back.
MPPT Product Page
MPPT Error codes
