I have installed Victron Venus OS on a Raspberry Pi 4. All works good, and can see it if I log in using IP address of it. But I would like to add a 'shutdown' option. I have seen online that you need to add some code - going in using Putty. My problem is that I cannot connect - says refused.
Is there also a place here that will show the code you add? On Youtube there are several videos that show it.
I have enabled SSH in the Settings, added password - but still no joy.
Incidentally, if I log on directly to my Pi using HDMI connection - just shows a black screen with option to try and log in - is this expected - would you ever log on directly? If yes, then what do you type to log in?
Any help would be most appreciated! Cheers!
